joining floors and walls priority
4 ANTWORTEN 4
Nachricht 1 von 5
895 Aufrufe, 4 Antworten
hey fellow reviteers i have a problem
i want to be able to conrol the way my floors cut my "foundation layer"
the way i want it to cut is the concrete slab cuts the leca and insulation layer but the insulation layer of my floor does not cut into the foundation layer
4 ANTWORTEN 4
Nachricht 2 von 5
martijn_pater
als Antwort auf: Anonymous
You can change your floor assembly -> edit floor type -> edit assembly and change priority under function (structure [1] / substrate [2] / thermal air [3] etc. Editing this there should resolve your issue probably.
Nachricht 3 von 5
 Suggested bedtime reading:  "About Applying a Function to a Layer of a Compound Structure".  It's a page-turner!
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Nachricht 4 von 5
als Antwort auf: martijn_pater
yes it should it just doesent matter what i set the layers to i could set it as finnish but would still cut trough structure
Nachricht 5 von 5
It should. Post your file.
