Joining Facia Boards From 2 Separate Sofits
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
BigPicture045
1081 Aufrufe, 4 Antworten
Please see the image below.
Description: You can see that the roof has two separate slopes. Two separate soffits were also created. The facia board is attached to the soffit board and because they are two separate pieces, I am having difficulty getting the facia boards to join nicely together.
Objective: Join facia board together that are connected to separate soffits.
Known work around: Use original roof line to create facia.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: BigPicture045
post the file.
Nachricht 3 von 5
mauricio_mssf
create different fascias:
1 - Fascia 1 - click on Restart Fascia (or Esc 2 times and activate the facia tool again);
2 - Fascia 2;
3 - move the points to adjust the position;
4 - Use the join tool.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 4 von 5
BigPicture045
als Antwort auf: mauricio_mssf
@mauricio_mssf  Getting a join error.
Nachricht 5 von 5
mauricio_mssf
I understood what happened, to solve this you need to change the way the end of each fascia behaves.
Separate the fascia, select one fascia and click on Modify Mitering (do this on both)
Select perpendicular and click on the line
Move the points and join them again.
See how it works here.
