Joined hatch only partially correct
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
ct_studio
167 Aufrufe, 2 Antworten
L1-L2 join gives a continuous hatch. It breaks when I join L2 to the parapet.
2 ANTWORTEN 2
Nachricht 2 von 3
jay_colcombe
als Antwort auf: ct_studio
If you use Tab you can select the hatch lines and move the to the correct place or use Align
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 3
syman2000
I assume those brick pattern hatch is model pattern. You can physically move the pattern. First you select the hatch line
Then you move them to next hatch pattern
