Join walls and floors
4 REPLIES 4
escobarfaiber
450 Views, 4 Replies
How can the white edge be removed both in elevation and 3D view when joining a wall with a floor? If it is possible to join these two elements in a section, why is it not displayed in elevation and the 3D view?
I have attached some images to illustrate the situation.
Thank you very much.
Labels (5)
4 REPLIES 4
Overlap them and then Join them together via Join Geometry. Note: they must be using the exact same Material.
Actually, I think this is what you are doing. If so, don't overlap and instead paint the edges with the same Material using the Paint Tool (Modify Tab).  Looks like you're using a Model Surface Pattern, so you'll likely need to align the Paint's Surface Pattern with the Wall's Surface Pattern. This is easily done. See Link below for instructions.
Help | Align the Surface Pattern on a Model Element | Autodesk
Thanks, Barth for your answer, that was helpful
I manually join walls and floors using the "attach" feature, but I find this process very disappointing. In other software, these junctions are made automatically. Every time I need to print a plan, I have to check these junctions to ensure structural continuity. I don't understand why Autodesk hasn't addressed this issue until now.
Even if I use a plug-in to create multiple junctions, I still need to check them afterward, and I often miss some junctions. How do you deal with these junctions? Any tips or solutions would be greatly appreciated.
