hi everyone. i have created roof by extrusion as shown on the attached file/image. i have tried using roof join but no luck at all. it didn't work. is there any way i can join the roofs to create corners? it would have been easy if there is a command like SWEEP in AutoCAD.
thanks everyone.
Gelöst! Gehe zur Lösung
Gelöst von nathanyiel. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi @nathanyiel
First of all of course there is a sweep in revit! The reson that you can't do join is because your roof dont intersect each other. i suggest you either extend your roofs so ther will be alignd and then use the join commen or you delete all and do it using sweep (recommended).
Good luck
thanks @zemeraloni. i will try it now and i will come back to you for the result. thanks again.
What you are describing is a mitering operation. Revit isn't capable of doing that. One solution would be to just sketch a section of roof at those corners and join the geometry when done. Or, you could redefine all three roofs into one monolithic roof with those two corners included.
hi @zemeraloni. seems like SWEEP can be accessed only when inside the family editor, or the like. if i select the roof, i can only edit the profile. thanks
@nathanyiel wrote:
hi @ToanDN. i also tried roof by footprint but i can't create the roof that i have sent.
See screencast from link below in about 10 minutes.
https://knowledge.autodesk.com/community/screencast/026ee6e3-a727-4718-8fc0-9945db83b158
wow! great! how can i remove the top portion of the roof? kindly see the attached image. thanks
