Join Nested Non-Shared Families
8 ANTWORTEN 8
Nachricht 1 von 9
552 Aufrufe, 8 Antworten
Dear All,
Is there a way to get rid of those lines (marked in yellow). I have joined nested non-shared families in the host family. In 3D view everything looks fine both in Family and Project Document, but in any planar view it is divided. Any suggestions?
I attach the family as well (RVT 2019)
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
I think that might be the least of your worries. Have you tried flexing it? I did. It broke to smithereens.
Nachricht 3 von 9
It shows okay in project, though.
Nachricht 4 von 9
als Antwort auf: barthbradley
I did. What do you mean it broke? Flexing works fine for me
Nachricht 5 von 9
als Antwort auf: ToanDN
Also when its cut? Can you send me screenshot that it's correct at yours?
Nachricht 6 von 9
Elevation is fine. Section is not.
Or you can make the component shared then join them in the project.
Nachricht 7 von 9
I mean when I changed certain user-entry parameters it broke. Plain and simple.
Regarding your join issue; you're going to lose joins anyways when you start flexing it.
Out of curiosity, why don't you use the stair tool?
Nachricht 8 von 9
Stair tool is too limited when it comes to custom shapes, so basically is useless in most cases...
With flexing all is solvable, so the problem lies in in-built elements visibility bahaviour
@ToanDN
shared nested families will not work with ifc export unfortunately
Nachricht 9 von 9
I don't know what you mean by "custom" shapes, but  99% of your monolithic straight flight family can be done using Revit Stairs. I would agree that there are some limitations with Revit Stairs, and I do see two conditions in your design that Revit Stairs can't do, but those would be relatively easy to "fix" in the Project.
FWIW
