Hi all,
I Want to know if it is possible to preserve a common line after joining to elements with same material.
N.B. I know it is possible to assing different matariel to the elements but it will cause issue in scheduling.
Linework not an option.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
You can override the cut.
All I use is the same color as the original solid gray color and modify one value so it is slightly different. You will see a light line showing.
I have tried to override by element as you described but still line not visible.
Can you record a screen cast or short video ?
no you can't, just extend the other wall and delete the short one. thanks
Did you modify the cut pattern color to 127-128-128?
Yes.
Whatever color I override same result. after joining no visible common line.
Could just unjoin them? Or draw a detail line? But I guess it's more of a question in general...
I think that maybe it is the best solution. Keep them unjoinded and override the common line.
Did you override by element? This is how I get the line show up because i just override one of the wall to have slightly different color than other wall.
I apply the same technique and it works fine. Only way to figure out is to upload the file.
