Join beam and column
Message 1 of 11
Hi community! how can i join the beam and column in red circle like attached image. Thank you!beam.jpg
Replies (10)
Message 2 of 11
ennujozlagam
hi ,pick column > join geometry > pick beam. hope it helps. thanks
Message 3 of 11
IT did not work
Message 4 of 11
RDAOU
Hello @Anonymous
Is there any other attached image besides the one with the circle?
If not; how does the current status of the beam and column look like now?
If you cannot attach the file; which columns/beams family are you using?
Message 5 of 11
ennujozlagam
hi, it works for me. you need to go to plan view > drag your beam to the middle of column > go to 3D view > pick your beam > join geometry > pick beam then your column then it will joined. hope it helps. thanks.
Message 6 of 11
beam1 copy.jpgno i want it join and trim like this
Message 7 of 11
ennujozlagam
hi, its totally different images from your first posted images? next time please more specific on what do you want to achieve. thanks
Message 8 of 11
A little misunderstood but this first post is what my problem is, and i want the solution to get the result like image above. Thank you community!
Message 9 of 11
ennujozlagam
hi, this is the simpliest way i can do. thanks
Message 10 of 11
Alan.johnson1970
Just a thought, make sure both column and beam are the exact same material (grade of Concrete)
In an  elevation you could add some ref planes and use them to cut the column as required.
AJ.
Message 11 of 11
RDAOU
@Anonymous
I am not sure why it is being complicated that much!!!
Beams and Column (Namely concrete ones) Join automatically as you draw them (an innate property Revit give to these elements). If you want it to join elsewhere or differently all you need to do is:
  1. Set your reference planes Horizontal and vertical to create an intersections to refer to in the 3rd step
  2. Use Unjoin to remove the Join envoked by default to the beam and column
  3. Drag your beam to the intersection where you need it to join/cut
  4. Re-apply join to columns and beams
Note:
The beam needs to be withing the bounding box of the Column... if it is too high above the column; the Join tool will not extend neither the column nor the beam. You need to adjust that using the handle controls or by adjusting Hight of the column in the properties palette
 If the above helps; kindly mark this replay Accept as Solution for the reference of other forum members seeking the same clarification
