Quick access toolbar is invisible when above the ribbon. I can see it when I put it below the ribbon though. Revit 2016.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Gelöst! Gehe zur Lösung
Gelöst von Kelsey.S. Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
It is a known problem when updating to windows 10...
Try this:
Or:
-Uninstall Dynamo
Hi @Ilic.Andrej,
I agree and suggest changing the Windows 10 Personalize settings to make the taskbars display with a color and disable transparency.
For more information on Windows 10 settings, see Customize Colors from the Microsoft Help site
The following forum post relates to your issue and has information on the solution of changing the title bar color.
See: Quick Access Toolbar invisible in Windows 10
If my reply was helpful, please Like or click the Accept as Solution button below (or both).
