Items that should be unseen in a section view
4 ANTWORTEN 4
Nachricht 1 von 5
navidnejat
227 Aufrufe, 4 Antworten
I have made a super family of a bathroom, loaded it onto a project, and have created a section on the cabinet looking away from the bath tub.
But in the section view, I still see the bath tub even though it is not supposed to be there. Is there some settings in the "edit family" that is causing this. I have attached both the plan view & the section view.
I would appreciate any suggestions. Thank you!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: navidnejat
Make the Nested Family Shared.
Nachricht 3 von 5
navidnejat
als Antwort auf: barthbradley
Sorry, how do I make the nested family shared?
I try to choose "shared parameter", but I'm unable to click ok & apply. Should I select the bath tub, click edit family, and make my changes there? Or can I just do this in the edit mode for the whole super family itself.
Thank you!
Nachricht 4 von 5
Edit all nested families in your super family make them Shared.
There are several posts with the same question in the last couple of weeks.
https://forums.autodesk.com/t5/revit-architecture-forum/seeing-behind-my-back-elevation/m-p/11327056...
Nachricht 5 von 5
First of all, that's a SHARED PARAMETER in your screenshot. That has nothing to do with making a Family Shared.  To make a Family Shared, you open the Family and check the "Shared" checkbox in the Properties. Afterwards, you need to RELOAD the Family into your "SUPER-DOOPER" Family and then RELOAD your "SUPER-DOOPER" Family into the Project.
