Items not showing in Section (Revit 2022)
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
tstewart
187 Aufrufe, 2 Antworten
The Base cabinets of a Kitchen island are not displaying on the Section drawing and I can't change the scale (greyed out). How to get the base cabinets to display and how to change the scale of the drawing?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: tstewart
Your view has a template so the scale is governed by the view template.  You either change scale of the view template; edit the view template and uncheck Scale box/or set the view template to None then change the scale of the view directly.
As for the cabinet visibility, there are a host of reasons, best is share the file.
Nachricht 3 von 3
tstewart
als Antwort auf: ToanDN
By changing the Template function to none, that worked.
Thank you,
TS
