Items disappear in local file
9 ANTWORTEN 9
Nachricht 1 von 10
435 Aufrufe, 9 Antworten
I have a very strange problem with a file in Revit 2018. I have generated the new central file of the file that the client sent me and everything is fine, the problem is that when I open a local file none elements appears any view, but if I open it detaching from central, everything is okey
Does anyone know what the problem is?
9 ANTWORTEN 9
Nachricht 2 von 10
hmunsell
als Antwort auf: Anonymous
check that when you opening the file, select the down arrow next to the open button and make sure you have ALL worksets checked.
Howard Munsell
Nachricht 3 von 10
MostafaElashmawy
May be the worksets are closed or hidden.
Mostafa Elashmawy
Nachricht 4 von 10
als Antwort auf: MostafaElashmawy
I have checked that configuration and everything is active, just like the filters and model categories.
The strangest thing is that when opening the file as local there is nothing visible, but if I do, separating from the center, all the elements all the elements are visbile normally
Nachricht 5 von 10
ennujozlagam
you can try to uncheck your use hardware acceleration from options  and update your graphics card driver to the latest and see if helps. thanks
Nachricht 6 von 10
RobDraw
Do you really mean opening a local file or do you mean create a new local from the central model?
Rob
Nachricht 7 von 10
als Antwort auf: RobDraw
I mean create a new local from the central model
Nachricht 8 von 10
als Antwort auf: ennujozlagam
I tried what you suggested but it didn't work.
I also tried open it directly from a local file and it seems that everything it's good. So it's what I'm going to do with this project
Nachricht 9 von 10
ennujozlagam
Where is your central file stored, in a network server or on your hard disk? Why do need to create a local file? And is there another user's are working in your central file? (because you didn't mention in your post how many user's working on that file). May I ask if you are familiar making a file into a central file? And creating a local file? Can share your file so we can check? Thanks
Nachricht 10 von 10
XXalessio.amodioXX
Go to Collaborate>Workset>Opened and Visible in all views
