IT IS REALLY SIMPLE...
7 ANTWORTEN 7
Nachricht 1 von 8
vincent.tiburcio
436 Aufrufe, 7 Antworten
Why doesn't Revit let you save a backup local before it completely crashes?... I just lost 2 hrs of work
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: vincent.tiburcio
It would if it could.
Meanwhile, set Save Reminder Interval and DO NOT ignore when it pops up asking you to save.
Nachricht 3 von 8
RobDraw
Saving often IS simple.
Rob
Nachricht 4 von 8
HVAC-Novice
Not having an autosave feature, that saves in the background while you still can work in the project, is one of the most missing features.
You can vote on a request to make this possible.
Until they provide that feature, manual saving after the reminder is all you can do.
Revit version: R2025.4
Nachricht 5 von 8
mhiserZFHXS
While I don't disagree that auto-save should probably be a feature, why in the world would you go 2 hours without saving? Even in programs that auto-save, I manually save at least every 30 minutes. Hopefully this is a hard lesson learned.
Nachricht 6 von 8
HVAC-Novice
als Antwort auf: mhiserZFHXS
I also sometimes find myself manually saving in Word or Excel, even if it autosaves. So I understand your paranoia :leicht_lächelndes_Gesicht:
But in Word/Excel the saving only takes as long as the click takes. Revit takes a few seconds during which you can't use Revit. This is annoying and I see how that prevents someone from saving "too often". I realize this is based on file size and network speed etc.
That is why I would hope an Auto-Save in Revit would work in the background while one still can use Revit. Basically, unnoticeable instead of pausing Revit every 15 minutes for a few looooong seconds.
I think OP learned their lesson the hard way. Sometimes that is the best way to remember the lesson....
Nachricht 7 von 8
mhiserZFHXS
als Antwort auf: HVAC-Novice
It'd be nice if that were implemented for all saving, not just the proposed auto-save feature!
Nachricht 8 von 8
HVAC-Novice
Goes without saying.  I would hope if they can figure out background-saving it would be the same for manual and auto-saving.
But you are right, one never knows.....
