Issues with wall sweep to match sloping roof profile.....
21 ANTWORTEN 21
Nachricht 1 von 22
2231 Aufrufe, 21 Antworten
Hi All,
Any idea how to trim wall sweeps to match the sloping profile of the roofline on the walls? I can get the sweeps to meet the wall edges and cut out the door frames but not the roof slope.
A quick reply would be much appreciated,
Thank you.
21 ANTWORTEN 21
Nachricht 2 von 22
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, can you please post some screen shot. thanks
Nachricht 3 von 22
Hard to visualize what you are trying to do, but have you tried editing the profile of your wall to meet your sloped roof line? The sweep will then stop at the new wall end.
Nachricht 4 von 22
als Antwort auf: ennujozlagam
The horizontal ones are internal wall sweeps, the vertical ones are external wall sweeps - hope this makes sense!
Nachricht 5 von 22
Yep, exactly what I thought. Did you try what I suggested?
Nachricht 6 von 22
als Antwort auf: barthbradley
Yes, tried it. But doesn't work!
Nachricht 7 von 22
Hmm. Can you post a file containing those elements?
Nachricht 8 von 22
@Anonymous
Wall sweeps are either horizontal or vertical. For slopes you need to manually create in place sweeps.
Nachricht 9 von 22
als Antwort auf: ToanDN
...I don't think he talking about angled sweeps.
Nachricht 10 von 22
Thank you, would you know the quickest steps to create these?
I've found some steps but they're too confusing!
Nachricht 11 von 22
Not too sure of sweeps can be angled? I found some info on other forums about creating 'in-place' sweeps but they're too confusing..
Nachricht 12 von 22
Just to be sure, are you wanting a new sweep to run along the slope or are you wanting the vertical sweep to be trimmed at the top to match the slope?
Nachricht 13 von 22
Dude, I never said you could do angled sweeps. Nor, did I think that you were talking about angled sweeps. I thought we were talking horizontal and vertical. I'm dazed and confused.
Nachricht 14 von 22
@ToanDN wrote:
...or are you wanting the vertical sweep to be trimmed at the top to match the slope?
This is how I read it. But, not the vertical. The horizontal.
Nachricht 15 von 22
paul
Bro! "Any idea how to trim wall sweeps to match the sloping profile of the roofline on the walls".  It's right there in the OP.  I'm trying to understand this as well but nobody has provided an easy answer.  Sweeps should have grips, IMO.
Nachricht 16 von 22
als Antwort auf: paul
Are you asking some question?
Nachricht 17 von 22
paul
No, I made two distinct points - 1) the OP made their point very clear so @barthbradley seems to have made too many comments not addressing the issue, and 2) sweeps don't seem to be very flexible.  Keep in mind that I've only been using Revit for about 8 months, but I'm an 18-year AutoCAD Architecture user.
Nachricht 18 von 22
Walk sweeps do have grips and they are not inflexible as you may think. What parts do you find them not flexible?
Nachricht 19 von 22
Nachricht 20 von 22
paul
And to @ToanDN:  See the sketch below, as I couldn't get the trim band to angle off properly with the slope of the roof.
I fully acknowledge my limitations in this software, but after having researched for two hours on how to create this clip, I finally just created an extrusion and it worked perfectly.  I tried creating the trim band as a stack wall component (but couldn't get it to work - probably my limitation, I'm sure), I tried attaching top to the roof as a wall sweep and it still didn't project to the roof slope, I tried doing a void extrusion and it said it couldn't cut it, and I added a wall sweep that would still not project to the roof slope after utilizing the 'attach top'.  I'm using Revit 2024.
