Hi
I have some serious issues with family text when printing something to PDF in Revit 2019. The text appears all messed up (see attached screenshot). This only happens to text within a family (e.g. keynote text, titleblock text) but not with the text within a schedule, for example.
I use NTI tools to print and this problem only appeared after the latest update of graphic card (running a MAC with Windows 10 on it). Tried to use Adobe PDF but same happens. However, a lot of my colleagues are running the same version of the graphic card driver and do not have the same issue.
Any ideas?
Thank you!
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Try to return to a previous driver version fro your graphics card and see what happens.
You also could try to go to a recent restore point (before update of your graphics card diver)
Louis
Please mention Revit version, especially when uploading Revit files.
Hi
Thank you. I did that and indeed it resolved the issue of the text. Now, unfortunately this driver version is causing my computer to freeze (unrelated to Revit). Stuck in a continuos loop of errors lately.
