I had issues with Dormer Opening as it behaves as Room bounding object. Dormer when using Dormer opening
Dormer using By face/Shaft/Vertical opening.
What I found out is that you have to use By Face/Vertical or Shaft opening to make it work.
Dormer opening on left side, vertical opening on right side.
Then you have to create new roof to fill in a gap to make it look same as using Dormer opening.
Blue part is a new roof filling void. Dormer roof can be then joined to it using Join/Unjoin Roof tool.
Then you need to join all parts together to make it look good.
I think that Dormer opening should be reviewed and somebody should fix this issue. Also making Model in place void and cutting roof with that doesn't work.
When Base offset is below roof, it leaves empty space when you Attach Base to the roof.
Attach Base to the roof was used.
When Base offset is above the roof, Attah Bse to the roof works fine and there are no white spots after the wall.
There are no white areas when Base Offset is above the roof and using Attached Base to the roof.
I think this are few bugs that should be fixed.
Hi @Anonymous
In that case avoid using the opening component, open the roof manually to get the current volume.
PN
Please click "✓ Accept as Solution" on the posts that helped you, so others in the community can find them easily.
PN
