Issues with element pivots when exporting from Revit to Unity
4 ANTWORTEN 4
Nachricht 1 von 5
caramendiaYWTYT
250 Aufrufe, 4 Antworten
Hello!
I am having issues with the pivots of elements when I export from Revit in .fbx format and import them into Unity.
The problem is that when I view the elements in Unity, the pivot is very displaced from the element. I have tried modifying the pivot in Revit to the point (0,0,0), but when I do this, what happens in Unity is that all the elements have the pivot in the same point in Unity. All the pivots are concentrated in a single point.
How could I export the model from Revit in such a way that the elements have their pivots correctly positioned in Unity and not displaced?
Thank you very much!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: caramendiaYWTYT
Nachricht 3 von 5
handjonathan
Hi @caramendiaYWTYT
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 5
caramendiaYWTYT
als Antwort auf: barthbradley
Thank you very much for your reply, @barthbradley .
The post refers to Blender. We use Revit for our model and still, after reviewing your post, we don´t find those options installed in Blender in Revit environment. We still obtain our pivots in Unity displaced from the elements and don´t know what to set in Revit to get the pivots in the 0,0,0  of each element.
Regards!
Nachricht 5 von 5
caramendiaYWTYT
als Antwort auf: handjonathan
Thanks @handjonathan for the follow up of the post! We don´t have yet the solution as we use Revit.
Regards!
