Issues with Editable Dimensions and Missing Room Polygons in DWG Export
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
se.ha
110 Aufrufe, 1 Antwort
Hello everyone
I've encountered a couple of issues when exporting a plan from Revit to AutoCAD (DWG):
-) Some dimensions in the exported DWG file are not editable in AutoCAD. There's no clear pattern as to which dimensions are editable and which are not.
-) Certain room polygons are not being exported. Again, there's no apparent logic to determine which room polygons are exported and which are not.
I tried all kinds of different export settings.
What could be causing certain dimensions to be non-editable in AutoCAD after export even though they are the same type as others? Why are some room polygons missing in the DWG export even though the room is visible in Revit and has the same properties as the neighbouring rooms?
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
1 ANTWORT 1
Nachricht 2 von 2
se.ha
als Antwort auf: se.ha
Looks like, for whatever reason, dimensions with superscripts are overridden during the export und thus are not editable:
se.ha
