issues viewing beams and columns
100268310
100268310
cannot see columns or beams in plan view to draw against the grid. can someone help ?
Basam.Yousif
Are they above your head? can you see them in a 3D view? are they turned off? is the view discipline not set to 'Coordination'? are they in a 'future' phase the view can not see? is there a filter?
 I fixed it thank you watched a you tube video. They were visible in 3d but I suppose the are set to place underneath the lowest level by -2000mm so I could not see them on any floor plan. I got around it but drawing the 1st column in the 3d and raising it up but still cant figure out how to change the setting in the propertie panel so I can place them easier. Thanks for responding though
