Having issues Printing to our KIP 7570k. The stamps are rotated and on the opposite side and no title block printed.
Any suggestions?
Build: Bluebeam Revu x64 2016.1
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community!
Please provide the following information:
1) Exact steps to reproduce
all files, journals, links, software versions, and printer settings ...including all views printed in Revit, Revit version, (whether latest update installed) all Revit printer settings, and all Bluebeam printer settings including advanced.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
It is not indicated what Revit version you are using, so the problem may be related with it. We suggest that you print PDFs using Docuflow 2.1 (fully functional for 7 days) that is available here and let us know if you experience the same error.
Luis Santos
archi systems as
L. Maas
Thank your post regarding the forum rules.
We require clarification when it is regarding to marketing. Obviously the other lines do not apply (including sales).
If we mention our own free app solutions you mean it is not a valid solution to the problem? In a broad sense a forum is by definition a marketing action from Autodesk and other players involved in giving assistanceto create value to the customer through support. So the support / marketing purpose of the forum is in contradiction with is own rules.
Luis Santos
archi systems as
