Hi there
I have added walls to the floor plan which show in the floor plan and a section however, they do not go to the top constraint, that I have set, in the 3D view.
Hi there
Solved by ToanDN. Go to Solution.
Select the Section box and drag the grip(s) to reveal the model.
Hi @ToanDN
I am an architecture student using Revit for the first time, and I am not completely sure what you mean by selecting the section box and dragging the grips.
Hi @ToanDN
Is this correct?
@Anonymous wrote:
Is this correct?
Yes you've got it.
@Anonymous wrote:
Is this correct?
Yes you've got it.
