Good Morning Everyone. I am having issues with room tags and door swings not appearing in ArcMap using the FME converter for Revit files. I have attached files my Revit project and what I am able to import into ArcMap for reference.
Hi @Anonymous
I see that you are visiting as a new member.Welcome to the Autodesk Community! ![]()
Which versions of Revit and ArcMap are you using?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you!
I am using Revit 2018 with the latest release of the FME Exporter and ArcMap 10.5.1
@Anonymous Revit version?
Viveka CD
The more I play with it the more it seems that I am missing something during the initial export from Revit. As in the room tags have to be selected/grouped with the floor plan prior to export.
@Anonymous Can you share the file to troubleshoot further?
I can send you a private folder if you'd like.
Also, can you verify that your computer meets the system requirements?
Viveka CD
Would you please send me a private folder if you don't mind. What do you need from my end to make that happen?
My computer definitely meets the system requirements.
Hi @Anonymous
I've shared a private folder with you (to the email you've set up in your profile).
Good to know that your systems requirements are fine.
I will need your files to test further and a journal.
Let me know if you have trouble accessing the folder and have any questions.
Viveka CD
Hi @Anonymous
Based on the jpg you attached initially, please upload you ArcMap file and journal as well.
Viveka CD
Hi @Anonymous
We are investigating and this issue is in progress.
Meanwhile, can you export the Revit model as an IFC file? Then Convert IFC to an ArcGIS Geodatabase and let us know if there is any difference.
Viveka CD
Hi @Anonymous
I'm checking back to see if you were able to try the IFC method?
I was able to try the export as an ESRI shapefile, SQLite spatial and FBX. The *.sqlite file works best with all elements intact.
Let me know if you have questions about these processes and export mechanisms.
I look forward to your reply.
Viveka CD
