Hi, I'm having trouble with the display of window sections in both floor plans and roof plans. For example, I’ve attached a window that I’m working with. When I import it into any model, it doesn’t display correctly in the roof plan—some elements of the window below the cut plane remain visible and cover what should be shown. I’ve already tried adjusting different visibility settings and modifying the view range, but the issue persists. Can anyone help me resolve this? Thanks!
...change your Project View's Detail Level. Try Fine. That resolve? If so, the issue is due to Visibility Settings of the geometry in the Family.
You may need to use a Plan Region.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-594B7B97-0D59-4B03-9544-E403BD03BE48
Steve Stafford
