Issue with the Sheet number not appearing on the Elevation Tag
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
micah
6985 Aufrufe, 6 Antworten
Hi All,
I recently had some issue with the Sheet number not appearing on the corresponding elevation tag even after placing the elevation view on the respective sheets.Also, I noticed that the sheet number appears for one of the elevations.It doesn't for the others.Kindly give in your inputs on how to resolve this.Attaching a screen shot of the error.
Micah
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: micah
Are the four elevations on the same Sheet?
Nachricht 3 von 7
micah
als Antwort auf: ToanDN
No! They are on two separate sheets.
Nachricht 4 von 7
That is the problem. One elevation bubble cannot show two different Sheet numbers in it. You need to either put them on the same Sheet, or create the elevations from separate bubbles.
Nachricht 5 von 7
micah
Thanks! It works now. I moved all the elevations to the same sheet.
Nachricht 6 von 7
bchaney0927
It would be a good feature to be able to split (click and drag the arrow on the symbol, for example) the different elevation markers when people end up in this situation.  That would help document production if you find that you can't fit all of those elevations on one sheet AFTER you've fleshed them out with detail and annotation.
Nachricht 7 von 7
als Antwort auf: bchaney0927
If you run into this situation, just Duplicate the elevation with Detailing, that will create another marker on top of the original, move it next to the original marker, delete the old elevation and place the new elevation on the sheet instead..
