Hi all!
I'm running into an issue with coordinates rounding. When trying to "specify a coordinates at point" it only allows me to input the Northing and Easting values to the accuracy of 1 decimal place before rounding, is there a way I can change this to be more precise?
Jack
Gelöst! Gehe zur Lösung
Gelöst von chrisplyler. Gehe zur Lösung
Try Manage>Project Units>Angle set to rounding to more decimal points
Hi Cliff B. Collins, thanks for the quick response.
I have just tried your suggestion, however, increasing the accuracy of the "Angle" value within Manage>Project Units> did not stop the coordinate value from rounding to 1 decimal place.
Interesting. @chrisplyler is spot on; this is a unit of length. What are your Project Units and Rounding set at for Length?
As @chrisplyler and @barthbradley have noted you need Units>Length. The North/South and East/West bearing values are Cartesian coordinate values relative to the coordinate system origin, not bearing...(angle).
Steve Stafford
