ISSUE WITH ROOM AND INVISIBLE WALL
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
mandraworkshop
555 Aufrufe, 11 Antworten
For some reason, my room shows the outline of an object or a wall which does not allow the SF to be accurate to the space. If I turn the phasing to "show all" there is no wall in that area (see screenshots). Any advice?
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: mandraworkshop
Reveal hidden elements.
It is easier to diagnose if you can share the file.  If not, go through this list:
https://www.revitforum.org/node/459
Nachricht 3 von 12
Nachricht 4 von 12
mandraworkshop
als Antwort auf: ToanDN
I tried that as well. nothing there!
Nachricht 5 von 12
mandraworkshop
als Antwort auf: barthbradley
I don't think it is. I checked and it appears that all my walls are joined. No gaps!
Nachricht 6 von 12
mandraworkshop
I think its a wall coming from the lower level. However, this particular wall doesn't come up beyond the first floor where I having this issue.
Nachricht 7 von 12
mandraworkshop
for some reason when I drag the lower level wall a few inches it fixed the room issue
Nachricht 8 von 12
Attach Top of those walls to the floor.
Nachricht 9 von 12
What direction?
Nachricht 10 von 12
Post a screenshot of your Warnings.
Actually, just post the file.  Let's stop guessing.  :zwinkerndes_Gesicht:
Nachricht 11 von 12
mandraworkshop
i moved to the right. I think I resolved the issue. I'm also working in options so it might have been that.
Nachricht 12 von 12
Sure sounds like the infamous "Gap" issue to me.   But whatever.
