issue with Pick Entire Walls - Selecte References - widths in Revit 2022
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
m.sega
642 Aufrufe, 15 Antworten
Hi, I'm new to revit, and I am starting to learn it  through some nice online courses, and I have faced many other problems but with search and some forum posts I have manged most of them.
But as shown in the screenshot in Revit 2022, I have chosen the following options to apply dimensions to this wall, which has 3 windows:
Dimension - Aligned - Wall faces - Pick Entire Walls - Selecte References - widths
so the issue is that it does not work, it works only if the openings in the wall are doors, and if they are windows it does not work.
Your help and suggestions would be appreciated.
15 ANTWORTEN 15
Nachricht 2 von 16
BDMackey
als Antwort auf: m.sega
The family must have an opening for this tool to work.  If the family has a void to cut the hole then it doesn't work.  Verify the window families you are using have openings in them.
Nachricht 3 von 16
m.sega
als Antwort auf: BDMackey
This is the properties of the Family, I do not know what to look for
Nachricht 4 von 16
m.sega
I think the Window family has already a cut in the wall
Nachricht 5 von 16
BDMackey
When you select the hole in the wall is it an opening or a Void?
Nachricht 6 von 16
m.sega
it is an opening cut
Nachricht 7 von 16
Basam.Yousif
A few thoughts:
1. Those windows are hosted on a different wall (host) than the one you are selecting to dimension. If so, try JOIN geometry between the two walls.
2. Windows are modeled as Curtain walls
Self-learning modern software (such as Revit) is not recommended. It's too complex and should be based on workflows, not buttons. There is so much misinformation online and when you dont know the difference, everything will look right.  You need an instructor from the same industry as you.
Nachricht 8 von 16
BDMackey
als Antwort auf: Basam.Yousif
Can you post the window family that you are using?
Nachricht 9 von 16
m.sega
Here is the file I am working on, it would be nice if someone could check it for me
Nachricht 10 von 16
BDMackey
When your window is loaded into another project it works fine.  When I copy your wall type into a new project it works.  All I can come up with is something is corrupt in your project...
Correction I created a new view and the tool works fine in that view, Found out that your View Range is set to the bottom of the window.  Didn't realize that if the view range is set to the same height as the opening it doesn't work.
Nachricht 11 von 16
m.sega
If I may ask, what is your Revit ver. ? Maybe it is something in the options, setting, or something else?
But thanks a lot for your help, that is mean the window and the wall both are correct, maybe then the project file has something else
Nachricht 12 von 16
BDMackey
I opened it in Revit 2022
22.1.1.516
20210921_1515(x64)
2022.1
I was able to reproduce the same quirk in 2021 as well
Nachricht 13 von 16
Basam.Yousif
Brian gets the cookie!
Nachricht 14 von 16
m.sega
Thanks a lot, it got resolved :lächelndes_Gesicht_mit_lächelnden_Augen:
Nachricht 15 von 16
Basam.Yousif
Thanks but @BDMackey solved it not me :leicht_lächelndes_Gesicht:
Please assign his response as the Solution.
Nachricht 16 von 16
m.sega
it is solved when you told me about the vie range
