Issue with Materials Library
mgnmasana
mgnmasana
I have installed and uninstalled Revit 2025.4 on my new laptop.  The materials are not showing in elevations/sections/3D views.  The materials library is installed, and I can see the materials selected in the materials browser under "appearance," but am not seeing them anywhere else?
nikpearce
Have you tried your view settings in the bottom left corner.
omniahassanin
  • Check Graphics Settings: Ensure that your graphics card driver is up-to-date and that your Windows updates are current. Sometimes, outdated drivers can cause display issues in Revit.
  • Reinstall Revit: Uninstall Revit 2025.4, verify that your graphic card driver and Windows updates are current, and then reinstall Revit 2025.4. This has resolved the issue for some users.
  • Reset Visual Settings: In Revit, go to the Visual Settings and reset them to default. This can sometimes resolve display issues.
  • Check Material Settings: Make sure that the materials are set to "Appearance" rather than "Graphic" in the General Settings.
  • Reinstall Revit 2024: If you previously had Revit 2024 installed and then uninstalled it, try reinstalling Revit 2024. The materials might have been removed when you uninstalled the previous version.
handjonathan
Hi @mgnmasana
Thanks a lot for posting your question to the forums!   Has the solution suggested by @nikpearce @omniahassanin  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
