Issue with Lineweight in Revit.
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
mr.engineer.aec
627 Aufrufe, 7 Antworten
Hi guys,
I have a problem with lineweight in Revit.
I want to Override Graphics Floor Plan to print. I want all line have lineweight = 0,005mm.
But when i overridegraphic by VV/VG, and choose lineweight = 1 so i don't receive lineweight = 0,005mm.
How can i solve this issue ?
Thank all.
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: mr.engineer.aec
hello, you can refer to this LINK. thanks
or minimum
Nachricht 3 von 8
Viveka_CD
Hi @mr.engineer.aec
The lower limit for Revit has always been .083 mm.
You could add support in Revit ideas. This issue currently has 22 votes. https://forums.autodesk.com/t5/revit-ideas/improve-line-weights-for-small-scale-drawings-remove-003-...
Thanks, @ennujozlagam for the link and your participation that is helpful in the forums!
Nachricht 4 von 8
 What printer can print a lineweight of 0.005mm?  Average human hair is between 0.06 and 0.08 mm.
Nachricht 5 von 8
mr.engineer.aec
 Sorry all,
It was my fault.
I mean 0,05mm.
And i can fill 0,05mm in Lineweight setting but lineweight of element in linked file is not override.
Can i override lineweight of element in linked in the host model ?
Nachricht 6 von 8
Is the Link set to "By Host" under the "Revit Links" tab in the Views Visibility and Graphics Override?
Are the Line Weights (under Additional Settings) of the Link Project the same as the Lines Weights of the Host Project?
Nachricht 7 von 8
mr.engineer.aec
als Antwort auf: barthbradley
@barthbradley
Is the Link set to "By Host" under the "Revit Links" tab in the Views Visibility and Graphics Override?   Yes, it is.
Are the Line Weights (under Additional Settings) of the Link Project the same as the Lines Weights of the Host Project?  No, and i edit as you say. Reload linked file, everything is ok.
Thank for your help.
Nachricht 8 von 8
Viveka_CD
