Issue with insert Rhino 7 to Revit 2020
travis.designer.vn
Message 1 of 11
travis.designer.vn
Hi
I test Insert Rhino WIP file to Revit.
There are only basic cube show in Revit 2020.
Please check.
Replies (10)
Message 2 of 11
Share 'em here and let us test.
Message 3 of 11
travis.designer.vn
Hi @barthbradley
This is rhino 7 file:
Message 4 of 11
I can't open a RAR. Can you use Windows?
Message 5 of 11
syman2000
I am having the same issue. Can you save the Rhino to older version and see if that able to solved the issue? Sketchup import also have the same issue with latest version.
Message 6 of 11
travis.designer.vn
Hi @barthbradley
I re-upload zip file:
p/s I use newest winrar, may be old winrar version can not open.
Message 7 of 11
You need to re-save it as Rhino 6.
...or, just do it in Revit. It's easy.
Message 8 of 11
travis.designer.vn
Hi @barthbradley  and @syman2000
This is result when saved as 3dm 6:
I'm testing Rhino 7 file compatible with Revit. In practical, model will be more complex.
Message 9 of 11
Let's see it. Post the R6.
Message 10 of 11
Export to DWG.
Message 11 of 11
travis.designer.vn
Hi @barthbradley
I upload attached file 3dm 6.
Hi @ToanDN
I'm testing posibility of importing 3dm 7 file.
