Issue with Cutting Using Void Form in Massing
0 ANTWORTEN 0
Nachricht 1 von 1
luisalexgl72
131 Aufrufe, 0 Antworten
I'm working on creating glass walls and need to cut out areas where columns intersect with the mass. The problem arises when using a Void Form to make these cuts. I’ve been working across 10 levels, but the cuts are only successful on 5 levels (and they are not consecutive).
When I try to use the Void Form on the other levels, it doesn't cut the mass as expected. Instead, the Void Form appears as part of the mass, but with orange-colored edges. I’ve confirmed that the Void Form is set to "Cut Geometry," and I also tried the "Cut" tool, but that doesn’t resolve the issue either.
Has anyone encountered a similar problem or knows a solution? Any help would be greatly appreciated!
0 ANTWORTEN 0
