Issue placing new rooms and room tags.
ericholmes98
ericholmes98
I am trying to place a room and associated room tag for some new rooms I am adding to my current project. Whenever I try and do this I get the error;
"None of the created elements are visible in Area Plan (Floor Plans): 1 MAIN FLOOR - WORKING/SPC View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
In this view/phase  I already have numerous rooms and room tags placed and can re-place/re-tag them without issue, it just seems like the new addition is where I am getting this error.
I have tried finding a solution but it seems like most of the solutions I found were for rooms that weren't enclosed or recognized by Revit at all which is not what I think is happening here.
Any advice or suggestions would be greatly appreciated!
Cheers
Check the Room Offset Values on Placement.
...check to see if Level is correct as well.
...if it's not the above, then check your View Range Settings.
se.ha
Hello @ericholmes98
The most obvious reason would be that rooms are disabled in the view template or through visibility overrides. Since you're working in an Area Plan, this might be the cause.
Cheers
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
ennujozlagam
try add value in your computations height?
ericholmes98
It seems like the levels are correct for these rooms. They are using the same view range settings as my other rooms on the same view which are displaying and tagging correctly. I am just having issues with these rooms I have drafted recently.
