Hi there,
I have a whole building on Revit, and I need to send to my client a specific room without sending the entire building information. Is there anyhow I can do this? Or do I need to build the room in a different file?
Thank you!
Anna
It is also possible to use the section box on a 3D view to see only the part of the model. The easiest way is to select the room and use the Selection Box command (BX for the shortcut).
Place that view on a sheet, then right click on the sheet in the Project Browser and hit "Save to new File". This will save that part of the model out as a separate file. It will not clip things like walls and/or floors but those can be edited in the new file to be smaller.
