Hello, a collaboration question.
Me (architect) adjusting my own file True North (41.92) from Project North. The question is in case Structural or Mechanical linked my file in order to coordinate, does my True North shows on their PC, in another way (Is True North user specified? or shared?
Thank you
Technically speaking everything is user specified since the user is entering it.
Is the true north shared? Not untill you publish to the linked models or the owners of the linked models aquire coordinates from yours (considering that your model would be linked into theirs)
Once you have published/acquired coordinates and saved sites, you will have shared coordinates established between all models
Note: if you are collaborating in BIM360 you can only acquire
Isn't true north already defined? It's the coordinates of the project that need to be shared in order to determine where it is in relation to the project.
