I have a linked architectural model that contains a bunch of rooms in my revit project. In Revit project, I am trying to create a room schedule with additional instance parameters inside my project (not in the linked model) that can be changed without going into the linked file. I was able to add new instance room parameters, however I can’t edit them. (I also tried using shared). Using Revit 2021.
Is there a way to do this? Or a work around?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
No. Schedule in main model can only report parameters from linked models, but cannot edit them. The only editable parameters are under RVT Link.
