I need to take developed sections like this in revit?
please reply soon, this will be very helpful. Thanks you.
@Anonymous
I would elaborate but I'm just not sure what exactly is being sectioned in the image you posted.
@Anonymous
In principle, yes. Section in Revit reflect the components placed in the model...If all the components are there, then your section would look just as you expect it to look like ![]()
Taking the image you posted as an example:
Thanks for your reply,
Our question is, How to get section view like red line, that means ,need to see 4 objects on walls.
Can you please send any screen cast/steps image to get clear procedure?
You can split segments a section line to create the jog around the walls like what you show.
@Anonymous
You cannot do that with one section line (to show 5 walls)...
@RDAOU , @ToanDN Thank you so much for your reply !
I have take section as shown in first image. So getting view like 2nd image.
But, we need to get a section as developed view as shown below! Is it possible?
I have attached revit file as well for your checking and getting easy solution. Thanks in advance.
@Anonymous
Read previous reply...you cannot unwrap in revit...you need to place several sections and the Overlay on the sheet
@Anonymous
I can share with you the Revit file for you to look into it...
(PS: have to admit I used dynamo to align crop region of each section to Reference planes but you do not need that, it can be done manually)
See attached .rvt
Shouldn't that be a topic for a new post?
@Anonymous
That sounded like a conditional statement!!! The purpose of this forum is to help other who are putting effort from there end ... not do the exercise from A to Z. You are the one on payroll ...
So you do not need to accept solution here. And if you decide to post your dynamo question as a new thread, I might consider helping if I sense that you have tried to put some effort or do some research but not able to get something to work
