is there anyway to change or add line styles in revit families?
dclouthier3PUEC
dclouthier3PUEC
We're trying to use the hidden lines in door family but do not want them blue. the line styles option is blocked and you can't click on it. is there a work around?
SteveKStafford
Linestyles in families are Object Styles. The project will use the project's Object Styles when the family is loaded regardless of what you set them to in the family.
Steve Stafford
handjonathan
Hi @dclouthier3PUEC
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
dclouthier3PUEC
yes it worked!
