If not, what will be the easiest way to make the exact same floor as the roof? It's a tricky roof with different elevations. The file is uploaded here
You can make this as a floor using "modify sub elements". Draw the floor boundary by picking the outline of the roofs you have made. then select the floor and click on modify sub elements from modify tab. then add your needed lines and points with add split line and add point, and move each point to have the requited height. please find the image attached.
