Is there any methods to lock the view
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
to1-2.wd
684 Aufrufe, 4 Antworten
although the eye elevation and target elevation already set
when insert other revit file.
the eye elevation and the target elevation will change
as a result nothing can see in the 3d view
Is there any method to lock the view?
THANKS
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: to1-2.wd
You can lock a 3D view using the lock icon on the bottom bar.
Nachricht 3 von 5
What are you talking about?  Your brief synopsis is sorely lacking details.  Elaborate your workflow and results so we can understand.
Nachricht 4 von 5
Liloust
Vous trouverez cet outils dans la barre en bas de votre écran (une petite maison avec un cadenas)
Tags (1)
Nachricht 5 von 5
Well, that's 2 for Lock View. I'm still on fence however - primarily because I don't understand your workflow.  What do you mean by "insert other Revit file"?
