Is there an installer for Revit 2020 now 2021 has been released?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
martin.horne98QZ6
420 Aufrufe, 2 Antworten
Good morning
Apologies if this is in the wrong forum. I had v2020 but upgraded to v2021 to open a number of files an individual had saved with v2021. Is there an installer available for v2020 to 'downgrade' the version? I now cannot run some third party add ons as they only work with v2020. Stupid mistake but it's done!
I no longer have the downloaded exe and the previous version was uninstalled to make way for the new.
Thanks in advance
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: martin.horne98QZ6
Updated to 2021? You mean installed 2021? Did you uninstall 2020? You didn't have to. Your license allows you to have 3 versions. Why not install 2020 next to 2021?  Go through your Autodesk Account Portal. You should see all available versions there.
Nachricht 3 von 3
martin.horne98QZ6
als Antwort auf: barthbradley
Yes, 2021 installed and 2020 uninstalled. Both together took up more room than I had available
Thanks, I was using the Autodesk desktop app which doesn't seem to have an option to install any previous versions once 2021 is installed. I have logged on to the website and there they are.
Appreciate the reply
