Is there an Education/Student version of Revit LT available?
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
4090 Aufrufe, 7 Antworten
I am a student and have a student version of Revit 2017.  I'm assisting another student who has Revit LT 2019, whose files of course I cannot open in Revit 2017.  Is there is a Revit LT 2019 student version available?  If not now, any plans to introduce education/student versions of Revit LT?  I see that Autodesk has student versions of both AutoCAD and AutoCAD LT; would be nice to have same with Revit.
If there is no Revit LT student version, I'll probably try the 30-day trial, or else see if I can get by having the other student export files to IFC format...
7 ANTWORTEN 7
Nachricht 2 von 8
Avaris.
als Antwort auf: Anonymous
Nachricht 3 von 8
Just to be clear, you don't need LT to open LT files. As the user above has linked you to, simply download a student version of Revit 2019. Full version can open LT files, there are just some limitations if you do things in full version that you may not be able to access in LT, such as filters.
You may find more info here: http://help.autodesk.com/view/RVTLT/2019/ENU/?guid=GUID-89BACB84-7B3F-44E3-A4A9-73507FAF23E3
Nachricht 4 von 8
Thanks, Damo3.  I understand I don't need LT to open LT files.  I don't want to upgrade from Revit 2017 (which I have currently) to 2019, as the school I attend has Revit 2017.  If I were to upgrade, files I work on at home wouldn't be readable on the school's computers.  I'm assuming that I can't have both Revit 2017 and 2019 running concurrently on the same PC.  But I thought perhaps both Revit 2017 and Revit LT 2019 could coexist on the same PC.  Since there doesn't seem to be a student version of Revit LT 2019 available, I may have to download a trial version of it to solve my issue for the time being.
Nachricht 5 von 8
DarrenP
if the software is not listed here: https://www.autodesk.com/education/free-software/featured then its not available under the education license
the only option for revit lt is to do a trial or buy atleast a monthly subscription
DarrenP
Nachricht 6 von 8
als Antwort auf: DarrenP
Thanks, Darren.  I had checked there before, just wanted to make sure I wasn't missing anything, or thought perhaps I might find out about plans to add Revit LT to the list of education software.  Seems the options you mention are my best bet for now.
Nachricht 7 von 8
Well lucky for you, you are assuming wrong. Unless someone knows something I don't, you can install multiple versions of Revit on your PC as a student. My students sometimes need to do it due to how versions are spread across the campus and priority of trying to keep up with upgrades.
Nachricht 8 von 8
Thanks, Damo, that's great to know, that different versions of Revit can coexist on the same machine.  I've installed a 30-day trial version of Revit LT 2019, but once the trial is up I'll try installing the student version of Revit 2019.
