AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Is there a way to use cut models created on curtan panel pattern family ?
11 ANTWORTEN 11
Nachricht 1 von 12
4804 Aufrufe, 11 Antworten
For example I want to cut these tiles that are created in  curtain panel pattern family which are used as component on a mass.
I already tried making a void in edit mode but it didn't work.
The only way I have come close to this is making a separate solid mass and cut out the tiles using cut geometry tool but now I can't get rid of the solid geometry because the tiles would revert back to it's original shape if I delete it.
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
What about changing the wall's shape to omit that section the using Edit Profile tool?
Nachricht 3 von 12
FAIR59
You can put the geometry you want to cut in a shared Generic Model family.
In the project environment you can then select and cut the generic model family using a "cutting" family . [ family containing a unused void and  (family)parameter "Cut with Voids When Loaded: checked]
Nachricht 4 von 12
als Antwort auf: FAIR59
That doesn't work at all even though it is cutting through things like walls
Nachricht 5 von 12
FAIR59
maybe I wasn't clear enough. You need to place all the geometry in a shared Generic Model family and nest that family into the curtain panel.
Here's an example using the Curtain Wall Panel family.
Nachricht 6 von 12
I think I should type the steps that I used so it would be easy to figure out what went wrong.
1.I went to new>family>metric generic model and modeled the geometry and saved it.
2)I selected an individual tile and selected edit family, then went to components>load family and load the above family into the project.
This is what looked like after loading  into the project.
If I just import the family,the family does cut through walls but it still wont cut through these tiles.
Nachricht 7 von 12
Use a Generic Model pattern based instead of the Curtain panel pattern based for the tile and you can use a face based family with a pre-cut void to cut each tile.
Nachricht 8 von 12
als Antwort auf: ToanDN
Are you supposed to select the cut geometry tool first and select the curtain model pattern and than select the void geometry?
I am unable to select the curtain model pattern after selcting cut geometry tool although I am able to cut through floors,walls ect.
Nachricht 9 von 12
Your roof tile must be generic model pattern based, NOT curtain panel pattern based.  Then you use just place the face based void on a tile and it automatically cuts.
Nachricht 10 von 12
It is modeled in  generic model pattern based but it still doesn't cut.So there must be something wrong with the generic face based family void that I used to cut.
Here is how I made it.
1.Go to new>family>generic model family faced based and modeled the void and exported in to the project after checking the cut with voids box.
Nachricht 11 von 12
You must cut the solid in the face based family with the void.  Do not need to check Cut with void when loaded, it's inapplicable here.  Load the family in your project and it will ask you to pick a face to place it, pick a tile and it will cut the tile.
Nachricht 12 von 12
nj19790605
great!!! very great!!! I love you
In Foren verƶffentlichen
