I tried in Dynamo with active selected elevation views with tag all, but it wont tag for the system dynamo tagging tool.
I went deeper with "get shape" nodes and "annotation tagging" tool, it will tag for some part but always missing something. Also, the "get shape/geometer" nodes will read the elevation as in 3D so everything even behind the elevation will be tagged unfortunately. However, if i just use the tag all not tagged from the API, either using material tag, or curtain panel tags, things went well correctly.
Just need help here to see, if by any chance, dynamo or other tools can function the same as the tag not tagged tool in the API, or if we can create a tool in dynamo to use this API to make an easy script to tag multiple elevation views for all walls/windows/curtain panels.
