We have a title block that has a raster image as background in the information area. It works fine and looks good. We tried to do it with a filled region but it hid some of the things on the title block.
However, when we try to add a legend (or any view), the title block hides it.
Isn't there a way to send the title block behind the views?
Is there a better solution to using a raster image as a background for the title block?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Sounds like you need a Title Block for those occasions where you need that space available. No?
Sorry I didn't reply sooner.
I ended up doing exactly this. Having a separate titleblock for sheets where I needed to use the space.
Thanks.
