Is there a way to set a different line color or line weight for each wall type
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
chhuanmawia18
1015 Aufrufe, 3 Antworten
Is there a way to set a different line color or line weight for each  wall type (or for a different type of an element) , to distinguish them while viewing in the wireframe or hidden line view. It is possible to set it using lineworks tool manually afterwards but it takes time
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: chhuanmawia18
You can override the wall colours and line types using filters in the view.  Go to your VG, Filters, and set a condition, such as wallls that contain 220mm have a certain colour and line type.  Set a different filter for each wall type that you want to display differently.
Nachricht 3 von 4
JANNIK.FATH
You can also just right-click the wall you want to overwrite > overwrite in view > pick your line and color.
If you only want to overwrite the exterior line of a certain wall you can also do that with linework (lw), pick the line and overwrite it.
Nachricht 4 von 4
chhuanmawia18
als Antwort auf: Anonymous
Thank you so much
