Is there a way to override plan view tags to be different than what the level it is derived from is called?
svalen
svalen
I have a level called "B.O.F"   I used this to create my foundation plan.
When I put this plan on a sheet, it is called BOF.    I'd like it to be called "Foundation Plan," but I want
it to still say BOF in sections and elevations.
What can I do/what is common practice to address this?
jvpantin2
View tags read automatically data from "View Name" parameter as shown in project browser and properties palette. For plan views, "View Name" is the name of the level associated (it can be changed w/o change level name); for elevations, sections and other view types is the used when created. The common practice is to keep this parameter fixed and fill "Title on Sheet" parameter, if you want your tag to show otherwise, very frecuent at documentation stage. It is a way to keep project browser structure and customize viewports and tags.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
So, why not give it a different Title on Sheet?
