If I just click and move an object, I can move up down, diagonally no problem. Using the MOVE command, then snapping to an end point of an item being moved, I'm forced to move along X or Y direction. Is there a way around this?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@David125 hi
I am not sure if this is what you are referring to but:
some elements may also require to you to check disjoin too
cheers
Dadgumit! It had to be so simple, I hate it when that happens. Thanks, that was it.
