Not sure why this view is overlaying the earth hatch through a footing. I know I can mask it but is there a way to do this globally? As I want to update our template.
Gelöst! Gehe zur Lösung
Gelöst von mhiserZFHXS. Gehe zur Lösung
Cut the topo with the footing. It can be a tedious process, especially if you have a lot of sections, but it does the job. And it'll also continue to show correctly even if the footing is moved around (not deleted and replaced).
I also posted an idea for this not long after toposolids launched, where other model elements automatically cut toposolids. Its been accepted but who knows when it'll be implemented.
https://forums.autodesk.com/t5/revit-ideas/model-elements-automatically-cut-toposolid/idi-p/12007651
