Is there a way to make room separation lines show which rooms they are affecting? I currently have a room like entity that is fully enclosed by RSLs. I see no gaps but Revit considers the room to be 'not fully enclosed'.
This is Revit 2019.2.6. Sadly, I must not share the files involved.
Can users know which level RSL were created on?
Gelöst! Gehe zur Lösung
Gelöst von Simon_Weel. Gehe zur Lösung
Separation Lines reside on the level on which they are created. So if you happen to have a couple of levels pretty close together and create Separation lines on both of these levels, then only the line created on the same level as on which the room is created will be honoured. The lines on the other level will be ignored.
To figure out on which level they have been created, you could create a section outside the rooms, switch on the separation lines and make a Windows selection around the level line.
Revit will still complain about room separation lines sharing the same positions but this worked out.
