I have added some Annotations and detail lines to an electrical plan in revit. I have another page that just has the garages in it. All of my lights show up on that view but none of my detail lines or annotations show up on it.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Select them, make a group (*), clipboard copy (CTRL+C), and paste aligned to the other.
* Make a group is optional, but if you later want to change them in one view and update the other then you just need to edit one group instead of copy paste again.
@HEVNBND wrote:
Thanks! Was not sure if that was the only way.
It is a common way, but not the only way. A few others:
- Create the Garage view as a Dependent of the Main view: details and annotation (for the most part) placed in Main view will show in Dependent view
- In the main view, select a model element that is supposed to show in both views, detail lines, annotation and create group. You will have a model group and an attached detail group. Open Garage view, select the model group and attach the detail group to it.
